1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
My DSL modem disconnects constantly. Time varies from 1 to 5 minutes.?
Discussion in 'Lounge' started by mrdimeo, Mar 23, 2008.
  1. mrdimeo
    mrdimeo New Member
    Wiring is dedicated. Appears to be AT&T server problem.
    Might go a day with no disconnects, then repeats.
  2. Colanth
    Colanth New Member
    That's why AT&T has a tech support department. Call them the next time it happens. It could be an intermittent in the modem, it could be a server problem, it could be a noisy line, it could be lots of things.
  3. peekay
    peekay New Member
    you do have the micro-filters that came with the modem plugged in between the phone socket and the wire going back into the modem don't you?
  4. Anatol Kuragin
    Anatol Kuragin New Member
    Try a different modem.
  5. Bumble_Bee
    Bumble_Bee New Member
    Check for the filter. Try installing a different filter. And check every phone jack at home. If there are devices connected on the same phone line, install filter on it.
    Check the dsl light on your modem. If it is flashing green/red, it means that the modem is trying to get the dsl signal from the CO. Try calling AT&T technical support, it might be a line problem then.
    1-800-722-3755 24/7 technical support
  6. BlueBoden
    BlueBoden New Member
