1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dedicated hosting or small business hosting
Discussion in 'Webhosting' started by exabeesg, Nov 18, 2016.
  1. exabeesg
    exabeesg New Member
    hi all, i plan to setup a website for my wholesale business. Which hosting service should i go for? Dedicated hosting or small business hosting?
  2. robert4u
    robert4u New Member
    It depends on your requirement if you have thousands of visitors go for dedicated servers, if you are just starting a website go for shared hosting.
  3. manoharparakh
    manoharparakh New Member
    When you choose a dedicated hosting provider, you get the full resources of single server. You don’t need to worry about other websites clogging up the server’s CPU and RAM. With a dedicated server, you can be sure that bad scripts running on another website or spikes in bandwidth usage won’t slow your server down.
  4. rickypinto
    rickypinto New Member
    It all depends on your business requirements and traffic on your website. Since you are planning for setup then you can go with either web hosting plans or with VPS server. These hosting services are good for any startup, small or medium-sized business. You can also upgrade the plans according to business performance. A dedicated server is also a good option, then when your business needs more resources and also not affect your pocket.
